By plinioseniore
#17631 Hi,
we have just ported Souliss on ESP8266, see below the screenshot of the Android application SoulissApp.
Here a sample sketch to run togheter with the Souliss library, I strongly suggest to download the whole IDE that contains the Arduino cores for ESP8266 that we have tested from this link.
Code: Select all /**************************************************************************
   Souliss - Hello World for Expressif ESP8266
   This is the basic example, create a software push-button on Android
   using SoulissApp (get it from Play Store).
   Load this code on ESP8266 board using the porting of the Arduino core
   for this platform.
 // Configure the framework
 #include "bconf/MCU_ESP8266.h"       // Load the code directly on the ESP8266
 #include "conf/Gateway.h"          // The main node is the Gateway, we have just one node
 #include "conf/DynamicAddressing.h"     // Use dynamic addressing
 #include "conf/DisableEEPROM.h"
 // Define the WiFi name and password
 #define WIFICONF_INSKETCH
 #define WiFi_SSID        "mywifi"
 #define WiFi_Password      "mypassword"
 // Include framework code and libraries
 #include "Souliss.h"
 // This identify the number of the LED logic
 #define MYLEDLOGIC     0
 void setup()
   Initialize();
   // Connect to the WiFi network and get an address from DHCP
   Setup_ESP8266();
   SetAsGateway(myvNet_esp8266);    // Set this node as gateway for SoulissApp
   // This node will serve all the others in the network providing an address
   SetAddressingServer();
   Set_SimpleLight(MYLEDLOGIC);    // Define a simple LED light logic
   pinMode(5, OUTPUT);         // Use pin 5 as output
 void loop()
   // Here we start to play
   EXECUTEFAST() {
     UPDATEFAST();
     FAST_50ms() {  // We process the logic and relevant input and output every 50 milliseconds
       Logic_SimpleLight(MYLEDLOGIC);
       DigOut(5, Souliss_T1n_Coil,MYLEDLOGIC);
     // Here we handle here the communication with Android
     FAST_GatewayComms();
This tiny sketch handle the communication with SoulissApp and control a relay (we have tested on Olimex ESP8266-EVB) on GPIO5.
Is just the simplest example, you can mix multiple ESP and control them from a central point, either SoulissApp or openHAB and have a network that contains also Arduino based on ATmega AVR that use 2.4 GHz radio like nRF24L01 and RFM69 or RS485 communication.
Have a try, and share your ideas!
