I am trying to upload a 150KB file from a NodeMCU to a remote server. The file has been uploaded to the module using the IDE SPIFFS uploader, where it is read by my program and I attempt to upload it to the remote server with 1 http.write command.
It seems that there is a packet limitation for http.write - somewhere around 3K in size? However, I've seen example code where people have suggested sending many hundreds of bytes is possible in fractions of a second (see https://github.com/esp8266/Arduino/issues/1853 ). When I split my code into numerous http.write instructions, it's very very slow. I'm communicating with the server successfully, and the headers I send are received properly. I just can't seem to find a way to send the binary file quickly.
Can anyone advise what I'm doing wrong in the code? A "conceptual" version of my code is shown below. (I've taken the specific server calls out to protect my client etc.) I'm using v2.3.0 of the library.
Thanks.
#include <Arduino.h>
#include <WiFiClient.h>
#include <WiFiUdp.h>
#include <SPI.h>
#include "FS.h"
#include "string.h"
#define USE_SERIAL Serial
char ssid[] = "ssid"; // your network SSID (name)
char pass[] = "Pass"; // your network password
WiFiClient client;
USE_SERIAL.begin(230400);
USE_SERIAL.printf("Connecting to WiFi");
WiFi.begin(ssid, pass);
WiFi.mode(WIFI_STA);
void loop()
// wait for WiFi connection
if (WiFi.status() == WL_CONNECTED)
const char* host = "host.com";
unsigned int content_length=0;
if (client.connect(host, 80))
client.setNoDelay(true);
char send_buf_header[400], send_buf_body[1000];
USE_SERIAL.println("Connected!");
memset(send_buf_header, 0, 400);
memset(send_buf_body, 0, 1000);
char *BOUNDARYSTR = "**BOUNDARYSTR**";
char BOUNDARY[100];
sprintf(BOUNDARY, "--%s\r\n", BOUNDARYSTR);
char ENDBOUNDARY[100];
sprintf(ENDBOUNDARY, "--%s--\r\n\r\n", BOUNDARYSTR);
// create http header
strcat(send_buf_header, "POST /v1/identify HTTP/1.1\r\n");
strcat(send_buf_header, "Host: host.com\r\n");
char tmp_buf[200];
sprintf(tmp_buf, "Content-Type: multipart/form-data; boundary=%s\r\n", BOUNDARYSTR);
strcat(send_buf_header, tmp_buf);
// create http body
int content_body_len = 0;
char *signature = "abcdefgh=";
sprintf(tmp_buf, "%sContent-Disposition: form-data; name=\"%s\"\r\n\r\n%s\r\n", BOUNDARY,"signature",signature);
memcpy(send_buf_body+content_body_len, tmp_buf, strlen(tmp_buf));
content_body_len += strlen(tmp_buf);
// more headers etc are defined here, which I have taken out to aid readability. I know this part of the code is ok.
sprintf(tmp_buf, "Content-Length: %d\r\n\r\n", content_body_len);
USE_SERIAL.println("Sending>>>>>>");
USE_SERIAL.println("(header)");
client.print(send_buf_header);
USE_SERIAL.println("(body)");
client.print(send_buf_body);
USE_SERIAL.println("(file)");
//**** This is where my problems begin!!! ****
/* This file upload technique works but is very very very slow!
#define MTU_SIZE 2*1460
for (int i=0; i<150000; i=i+MTU_SIZE) client.write(&bigfile[i],MTU_SIZE);
client.println();
// This is what I'm trying to get to work....
SPIFFS.begin();
File spiFile = SPIFFS.open("bigfile.bin", "r");
if (!spiFile) USE_SERIAL.println("file open failed");
else USE_SERIAL.println("wav file opened");
client.write((uint8_t)spiFile); // only sends 1 byte, throws an error unless I cast it????
//client.write(spiFile);
spiFile.close();
client.println();
sprintf(tmp_buf, "%sContent-Disposition: form-data; name=\r\n\r\n\r\n", BOUNDARY);
client.println();
client.print(ENDBOUNDARY);
USE_SERIAL.println(">>>>>>Complete");
if(!eRcv());
client.stop();
while (client.connected())
if ( client.available() )
char str = client.read();
Serial.print(str);
delay(10000);
byte eRcv()
byte respCode;
byte thisByte;
while(!client.available()) delay(1);
respCode = client.peek();
while(client.available())
thisByte = client.read();
Serial.write(thisByte);
return 1;
