I do not have esp-01 and I have only esp-12e and above.
The problem with our society are getting too rich and lazy so they dump old stuffs for new even though these old stuffs can still do the same job.
Explore... Chat... Share...
The code you installed was likely meant for the ES[…]
Thanks a lot for sharing this project.
Yes, there are examples of connecting to an ESP826[…]
Using an ESP8266 to read the duty cycle of the sea[…]
Positioning the ESP-32 on top to dissipate heat is[…]
It sounds like the two Sonoff Basic devices you ar[…]
Some similar problems have been discussed in the f[…]
If you're facing issues with the anemometer, you c[…]
I understand that delay Microseconds might be clos[…]
It looks as though you are not passing enough para[…]
The issue is solved. 1) TTUSB0 is taken by BRLTTY […]
You have to install the <FirebaseESP8266.h> […]
I decided to use 3.2 V lifopo4 battery and discard[…]
An official web portal created by Kroger is called[…]
Follow US on Twitter and get ESP8266 news and updates first.
