Most project and tutorial uses nodeMCU as the module for sending data to firebase.
I really need help. Thank you in advance.
Explore... Chat... Share...
rudy wrote:Modules that do not include a 3.3 volt regulator (ESP-01, ESP-12, ESP-M3, ESP-07, ...) are difficult to use. The ESP8266 needs a very good power supply. Good decoupling. The ESP-01 is not as easy to use as a Bluetooth module. The peak current requirements are much higher. And this can lead to unstable operation.
You will write a program and you will never know if the unstable operation is caused by code issues or by poor power. It is highly recommended to develop with a Nodemcu or Wemos type board. Get your code working on those, and then if you have a good reason to want a bare module then give it a try.
Thanks for sharing. Earlier I came across a tutori[…]
Thanks for all the help. PCB's arrived and works l[…]
We know SPI has some configurations. For example, […]
Some help wanted pointing me in the right directio[…]
Hi, I have the sample problem. Esp is online the w[…]
In case someone else comes looking for an answer i[…]
Project description: 1.CY8CKIT-059 is Master and E[…]
One cause of this is when the flash doesn't suppor[…]
This question was already once asked. The origin[…]
The exit status of 2 is just the standard error st[…]
Follow US on Twitter and get ESP8266 news and updates first.
