By Bert
hackrid wrote:seems we have to bypass the license stuff "some how" ?!
That's simple enough. There are self-served licences included, but those are only valid until 28-jun-2014. We can however still use them.
Set back the clock for a year (or any other sufficient period of time):
  • Disable internet time synchronization (double-click on time, third tab, leftmost button at bottom is "OK" as usual)
  • Shutdown VM
  • Set back BIOS time 1yr: VBoxManage modifyvm ESP_IOT_SDK --biossystemtimeoffset -31536000000
  • Start the VM again
Start the licensing server through the "xtensa" shortcut on the desktop. From here on Xtensa Xplorer can properly "validate" its license and functions as it should.
By leblebitozu
#82 At the link http://bbs.brieflive.com/forum.php?mod=viewthread&tid=2 talking about these documents ;
1, how to compile the project: Espressif IoT SDK Manual v0.5.pdf
2, how to download the program: Espressif IoT SDK Manual v0.5.pdf
3, how to debug: Espressif IoT Demo Manual v0.1.pdf
4, the general structure of the code: Espressif IoT SDK Programming Manual v0.6.pdf
I cant find it none of them in the VM image, do you know where is this documents ?
By tinhead
#110 btw, there are driver sources for the ESP8089 in "kernel_rockchip-radxa-radxa-dev-kk". This is in principle ESP8266 with Miracast feature added.
