Having almost 35 years of electronical/software engineering experience, I'm usually voting for safe bet.
But in case of ESPs, my experience changed a lot, I'm now even playing strong safety !
Let's just imaginate an ESP devices in the fields with harsh environment which his doing deep-sleep for a certain amount of time, and then it wake-up exactly at the moment when ESD is stronger than the weak internal pullups and driving the GPIO0 or GPIO2 to a level equivalent to LOW (yes, ESD is AC, so it can act an LOW or as HIGH depending of it waves), the ESP will simply wake-up in a bad mode, device been stucked there forever until you recycle the power to make it run again.
Now, why having those external pullups even if there are some internal ones ? Simply because those internal ones are too weak ! Maybe Expressif should have choosen stronger ones.
Just to prove that, their document 0B-ESP8266__Hardware_User_Guide__EN_v1.1.pdf (http://bbs.espressif.com/download/file.php?id=562) has a contradiction (which seems to admit the above facts) :
In the Section "2.2.2 Power-on Sequence and Power Reset", they mentioned "There is an internal pull-up in the CHIP_EN pin, so no external pull-up is needed." and few lines later "If voltage for CH_EN pin is low, the chipset ESP8266EX will power off. Note that this pin cannot be dangled.".
So, this means they admit that an external strong pullup is NOT superfluous ...
Also, in the same section, they mentioned "There exists internal pull-up resistor in the reset pin, Pin32, which can be left dangled when it is not used. When the chip is enabled, the reset pin is held low. In order to avoid reset caused by external interference, the lead is generally required to be short, and no external pull-up resistor is necessary.".
We all remember that many people on the forum have posted thread about this reset issue due to "antenna effect", but here, in this case, Espressif never updated their specs specifying not to leave the pin dangled, but maybe they will in the future.
All this is true with ANY critical pins, even if GPIO0/GPIO2 is read only during few nanoseconds, the "antenna" effect still can lead to improper state.
The conclusion is that I've always said that since the beginning, member "Cal" stated more than 6 weeks ago that I was right because he understand what is the "antenna" effect, and I'm pretty sure there are several other members who already agree but they did not given their voice yet here.
