hreintke wrote:LS,
Not sure why but when I include theCode: Select allwifi_station_set_reconnect_policy(true);
into an example application I can compile without errors.
Earlier usage of other sdk functions needed additional effort so there must be difference between sdk functions.
Can you try whether your application compiles and runs OK ?
If yes, I will further investigate why and which difference exist
Amazing! You are right. I can compile! I am using Eclipse devkit from Cherts. One thing unusual I do notice is that the Eclipse IDE shows "Function wifi_station_set_reconnect_policy could not be resolved". However, when I compile the code, no problem! SMING is even better than all of us thought!
Did you see this warning "Function wifi_station_set_reconnect_policy could not be resolved"? If yes, how did you resolve it?
