- Wed Oct 07, 2015 2:12 pm
#30824
Vincent Lê wrote:The external source is a button, so it is less than 250ms.
With this idea, I'm trying to implement a RC circuit between my button, the reset pin and a gpio pin. This will electronically store a value in the capacitor.
I think this is the good idea, unfortunately I am failing to implement it. How would you do that?
Hi, some thoughts. All assume that you are connecting GPIO16 to RST to get out of deep sleep via a 1k resistor and the RC needs to keep the pin high for about 1 sec.
1. Dual pole switch. One side to RST to wake from deep sleep. Other side to GPIO of your choice, with RC (to provide delayed off). Assumes the button press is long enough to wake ESP.
2. Single pole switch. Assumes the button press is not long enough to wake ESP. Switch charges RC – that provides voltage to GPIO of your choice & RST via diode (diode stops GPIO going high during normal wake from sleep).
3. Long shot but simple. This assumes that GPIO 16 goes high to wake the ESP for long enough to be read by another pin. Single pole switch provides voltage to RST.
IMAGE REMOVED OR MY DROPBOX GETS FULL - PM me if you think it might have been of use to you.
That should keep you busy for an hour or so.
