I want to use the external RST pin of the ESP03 and ESP01 modules from an other digital circuit. The issue is that the external CMOS circuit can't sink a lot of current: max 10mA.
So I took some current measurement recently on the RST pin and I got this face:
![Surprised :o](./images/smilies/icon_e_surprised.gif)
Just pulling down to GND the RST pin with a pushbutton caused 45mA flowing through the wires!!!!!!
I tried to pull it low with a 100Ohm, the voltage dropped only to 2.45V. (my power supply is 3V)
So after a short calculation I got 34 Ohms as an internal pull-up resistance value at RST pin.
This looks realy strong pull-up!!!!
I am still affraid that the RST pin will kill my other electronics
Do you have any suggestions? Or did you experience the same?
My alternative ideas to solve the problem:
- Use CH_PD input as a RESET with a pullup resistor. Any issues, experiences on this? Will the device boot up the same?
- Use a MOSFET transistor just to pull to 0 the RST pin - this would be costly, and many external circuit just for this. :S any oppinion??
Thanks for your advice or sharing your experience!!
