By wewa00
#60354 I like to configure my ESP8266 with WiFiManager. After each power cycle, the config portal should open and wait for a new configuration. If there is no new configuration entered, WiFiManager should autoconnect with the last/old configuration.
For this I modified AutoConnectWithFSParametersAndCustomIP.ino slightly as you can see here:
Code: Select all#include <FS.h>                   //this needs to be first, or it all crashes and burns...
#include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h>          //https://github.com/bblanchon/ArduinoJson
//define your default values here, if there are different values in config.json, they are overwritten.
//length should be max size + 1
char mqtt_server[40];
char mqtt_port[6] = "8080";
char blynk_token[33] = "YOUR_BLYNK_TOKEN";
//default custom static IP
char static_ip[16] = "10.0.1.56";
char static_gw[16] = "10.0.1.1";
char static_sn[16] = "255.255.255.0";
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
  //clean FS, for testing
  //SPIFFS.format();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(mqtt_server, json["mqtt_server"]);
          strcpy(mqtt_port, json["mqtt_port"]);
          strcpy(blynk_token, json["blynk_token"]);
          if(json["ip"]) {
            Serial.println("setting custom ip from config");
            //static_ip = json["ip"];
            strcpy(static_ip, json["ip"]);
            strcpy(static_gw, json["gateway"]);
            strcpy(static_sn, json["subnet"]);
            //strcat(static_ip, json["ip"]);
            //static_gw = json["gateway"];
            //static_sn = json["subnet"];
            Serial.println(static_ip);
/*            Serial.println("converting ip");
            IPAddress ip = ipFromCharArray(static_ip);
            Serial.println(ip);*/
          } else {
            Serial.println("no custom ip in config");
        } else {
          Serial.println("failed to load json config");
  } else {
    Serial.println("failed to mount FS");
  //end read
  Serial.println(blynk_token);
  Serial.println(mqtt_server);
  // The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
  WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 5);
  WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 34);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //set static ip
  IPAddress _ip,_gw,_sn;
  _ip.fromString(static_ip);
  _gw.fromString(static_gw);
  _sn.fromString(static_sn);
  wifiManager.setSTAStaticIPConfig(_ip, _gw, _sn);
  //add all your parameters here
  wifiManager.addParameter(&custom_mqtt_server);
  wifiManager.addParameter(&custom_mqtt_port);
  wifiManager.addParameter(&custom_blynk_token);
  //reset settings - for testing
  //wifiManager.resetSettings();
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  wifiManager.setMinimumSignalQuality();
  //sets timeout until configuration portal gets turned off
  //useful to make it all retry or go to sleep
  //in seconds
  wifiManager.setTimeout(120);
  //fetches ssid and pass and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  if (!wifiManager.startConfigPortal("AutoConnectAP", "password")) {
    Serial.println("failed to connect and hit timeout");
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(5000);
  //if you get here you have connected to the WiFi
  Serial.println("connected...yeey :)");
  //read updated parameters
  strcpy(mqtt_server, custom_mqtt_server.getValue());
  strcpy(mqtt_port, custom_mqtt_port.getValue());
  strcpy(blynk_token, custom_blynk_token.getValue());
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["mqtt_server"] = mqtt_server;
    json["mqtt_port"] = mqtt_port;
    json["blynk_token"] = blynk_token;
    json["ip"] = WiFi.localIP().toString();
    json["gateway"] = WiFi.gatewayIP().toString();
    json["subnet"] = WiFi.subnetMask().toString();
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    //end save
  Serial.println("local ip");
  Serial.println(WiFi.gatewayIP());
  Serial.println(WiFi.subnetMask());
My Problem is, that it does not connect after timeout. Only the config portal is closed.
What do I need to change, so that it automatically connects after timeout?
By mrburnette
#60375
My Problem is, that it does not connect after timeout. Only the config portal is closed. - See more at: viewtopic.php?f=32&t=13168#sthash.I3KxJ1sF.dpuf
Does the original, non-modified version work correctly? Or, does it exhibit the same issue? I'm just trying to determine if the current functionality has always been in the code or if you introduced that behavior.
Windows has a great product in WinDiff and Linux has a good product in Meld. I suspect OS-X has a quality, free file compare utility that you can use to compare two source files assuming that the concern was introduced in your update.
Ray
By wewa00
#60378 The original version did not have this issue, because timeout was disabled there (as you can see in the diff below).
Code: Select all--- AutoConnectWithFSParametersAndCustomIP.ino
+++ AutoConnectWithFSParametersAndCustomIP_MyVersion.ino
@@ -126,19 +126,19 @@
   //defaults to 8%
   //in seconds
-  //wifiManager.setTimeout(120);
+  wifiManager.setTimeout(120);
-  if (!wifiManager.autoConnect("AutoConnectAP", "password")) {
+  if (!wifiManager.startConfigPortal("AutoConnectAP", "password")) {
     delay(3000);
     ESP.reset();
     delay(5000);
But I got an idea how to get things working the way I plan.
I think I will only need to call
Code: Select allwifiManager.autoConnect("AutoConnectAP", "password")
in case
Code: Select allwifiManager.startConfigPortal("AutoConnectAP", "password")
hits a timeout (in that case it returns False).
I'll give that a try and report afterwards.
By wewa00
#60594 I found a solution which connects automatically to an AP (one that was configured via ConfigPanel in some previous session) if the ConfigPanel times out. The only problem is, that the ESP uses a dynamic ip instead of the configured static ip.
I only needed to do the changes in AutoConnectWithFSParametersAndCustomIP.ino I mentioned before. Here are the changes I made again.
   //defaults to 8%
   //in seconds
     delay(3000);
     ESP.reset();
     delay(5000);
   } - See more at: http://www.esp8266.com/posting.php?mode=reply&f=32&t=13168#sthash.epUpWHWD.dpuf
But there are two points I wonder about or which seem strange.
  1. Why is the ESP8266 automatically connecting to an AP if the ConfigPortal times out?
  2. Why is the ESP8266 using a dynamic ip if the ConfigPortal times out?
