Just want to say thank you tot the TS and all! This post helped me a lot with my first steps in LUA on the ESP, I like it
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Cheers,
Kees
The issue with the duplicate page appeared to be caused by the browser making two separate posts (one without the form data and one with data) or a single posts which was split on the ESP8266, I'm not sure. So the code handling the requests was executed twice and therefore the page was sent twice as well.
I have updated the code (and split the functions a bit) to solve this:
wifi.setmode(wifi.STATION)
wifi.sta.config("<SSID>","<code>")
outpin=4 -- Select right IO index !! Here is settings for GPIO2 (Lua build 20141219)
gpio.mode(outpin,gpio.OUTPUT)
gpio.write(outpin,gpio.LOW)
status = 'OFF'
function ctrlpower(kdesi,payload)
pwm.close(outpin)
dotaz=string.sub(payload,kdesi[2]+1,#payload)
status = dotaz
if dotaz=="ON" then gpio.write(outpin,gpio.HIGH) return end
if dotaz=="OFF" then gpio.write(outpin,gpio.LOW) return end
if dotaz=="FLC" then pwm.setup(outpin,2,512)pwm.start(outpin) return end
pwm.setup(outpin,1000,dotaz*10)
pwm.start(outpin)
end
function sendPage(conn)
conn:send('HTTP/1.1 200 OK\n\n')
conn:send('<!DOCTYPE HTML>')
conn:send('<html>')
conn:send('<head><meta content="text/html; charset=utf-8"><style>input{width: 100px; height: 100px;}</style>')
conn:send('<title>ESP8266</title></head>')
conn:send('<body><h1>LED Controller</h1>')
conn:send('Status: <b>')
if (status == "ON") then conn:send('ON')
elseif (status == "OFF") then conn:send('OFF')
elseif (status == "FLC") then conn:send('Flickering')
else
conn:send(status)
conn:send('%')
end
conn:send('</b><br /><br />')
conn:send('<form action="/" method="POST">')
conn:send('<input type="submit" name="pwmi" value="OFF"/>')
conn:send('<input type="submit" name="pwmi" value="ON"/><br /><br />')
conn:send('<input type="submit" name="pwmi" value="10"/>')
conn:send('<input type="submit" name="pwmi" value="20"/>')
conn:send('<input type="submit" name="pwmi" value="30"/>')
conn:send('<input type="submit" name="pwmi" value="40"/>')
conn:send('<input type="submit" name="pwmi" value="50"/>')
conn:send('<input type="submit" name="pwmi" value="60"/>')
conn:send('<input type="submit" name="pwmi" value="70"/>')
conn:send('<input type="submit" name="pwmi" value="80"/>')
conn:send('<input type="submit" name="pwmi" value="90"/> % of power<br /><br />')
conn:send('<input type="submit" name="pwmi" value="FLC"/> HW blinker</form>')
conn:send('</body></html>')
end
srv=net.createServer(net.TCP)
srv:listen(80,function(conn)
conn:on("receive", function(conn,payload)
--next row is for debugging output only
--print(payload)
if (string.find(payload, "GET / HTTP/1.1") ~= nil) then
print("GET received")
sendPage(conn)
else
kdesi={string.find(payload,"pwmi=")}
--If POST value exist, set LED power
if kdesi[2]~=nil then
print("Command received: " .. payload)
sendPage(conn)
end
end
end)
conn:on("sent", function(conn)
conn:close()
print("Connection closed")
end)
end)
This code works fine now and also shows the current status.
kdesi={string.find(payload,"pwmi=")} --find the location of "pwmi= in the payload
This parts makes sense. Two lines down from that, we have this:
if kdesi[2]~=nil then --??
Why is this needed? I see that it is checking to see something is in kdesi, but why the second element?
Also, if I print "kdesi" in the function "ctrlpower", I get something printed like "table: 3fff7280" why?
BTW, this thread has been a huge help.
