- Wed Nov 14, 2018 5:05 am
#79137
QuickFix wrote:I took the liberty of downloading the installer and extracted the file for you.
This is what the virgin file looks like:Code: Select all# !!!!!!!! UNLIKE PREVIOUS VERSIONS OF PROCESSING !!!!!!!!!!
# DO NOT MODIFY THIS FILE, OR DELETE SETTINGS FROM THIS FILE
# These are the default preferences. If you want to modify
# them directly, use the per-user local version of the file:
# Documents and Settings -> [username] -> Application Data ->
# Processing -> preferences.txt (on Windows XP)
# Users -> [username] -> AppData -> Roaming ->
# Processing -> preferences.txt (on Windows Vista)
# ~/Library -> Processing -> preferences.txt (on Mac OS X)
# ~/.processing -> preferences.txt (on Linux)
# The exact location of your preferences file can be found at
# the bottom of the Preferences window inside Processing.
# Because AppData and Application Data may be considered
# hidden or system folders on Windows, you'll have to ensure
# that they're visible in order to get at preferences.txt
# You'll have problems running Processing if you incorrectly
# modify lines in this file.
# DEFAULT PATHS FOR SKETCHBOOK AND SETTINGS
# relative paths will be relative to processing.exe or procesing.app.
# absolute paths may also be used.
# note that this path should use forward slashes (like unix)
# instead of \ on windows or : on macos or whatever else
# If you don't want users to have their sketchbook default to
# "My Documents/Processing" on Windows and "Documents/Processing" on OS X,
# set this to another path that will be used by default.
# Note that this path must exist already otherwise it won't see
# the sketchbook folder, and will instead assume the sketchbook
# has gone missing, and that it should instead use the default.
#sketchbook.path=
# if you don't want settings to go into "application data" on windows
# and "library" on macosx, set this to the alternate location.
#settings.path=data
# temporary build path, normally this goes into the default
# "temp" folder for that platform (as defined by java)
# but this can be used to set a specific file in case of problems
#build.path=build
# By default, no sketches currently open
last.sketch.count=0
# by default, check the processing server for any updates
# (please avoid disabling, this also helps us know basic numbers
# on how many people are using Processing)
update.check = true
# on windows, automatically associate .pde files with processing.exe
platform.auto_file_type_associations = true
# GUI - Scaling, edit this to scale to higher dots-per-inch displays
# "auto" means autodetect.
gui.scale=auto
#gui.scale=200
# default size for the main window
editor.window.width.default = 500
editor.window.height.default = 600
editor.window.width.min = 400
editor.window.height.min = 290
# the following commented out to better support netbooks
# http://code.google.com/p/arduino/issues/detail?id=52
#editor.window.height.min = 500
# tested as approx 440 on OS X
#editor.window.height.min.macosx = 450
# tested to be 515 on Windows XP, this leaves some room
#editor.window.height.min.windows = 530
# Enable code folding
editor.code_folding=false
# font size for editor
editor.font=Monospaced,plain,12
# Monaco is nicer on Mac OS X, so use that explicitly
editor.font.macosx = Monaco,plain,12
# anti-aliased text, turned on by default
editor.antialias=true
# color to be used for background when 'external editor' enabled
editor.external=false
# caret blinking
editor.caret.blink=true
# area that's not in use by the text (replaced with tildes)
editor.invalid=false
# show line numbers in editor
editor.linenumbers = false
# enable ctrl-ins, shift-ins, shift-delete for cut/copy/paste
# on windows and linux, but disable on the mac
editor.keys.alternative_cut_copy_paste = true
editor.keys.alternative_cut_copy_paste.macosx = false
# true if shift-backspace sends the delete character,
# false if shift-backspace just means backspace
editor.keys.shift_backspace_is_delete = true
# if set to true, home/end keys will go to the start/end of current line
editor.keys.home_and_end_beginning_end_of_doc = false
console = true
console.output.file = stdout.txt
console.error.file = stderr.txt
console.lines = 4
# set to false to disable automatically clearing the console
# each time 'run' is hit
console.auto_clear = true
# set the maximum number of lines remembered by the console
# the default is 500, lengthen at your own peril
console.length = 500
# convert tabs to spaces? how many spaces?
editor.tabs.expand = true
editor.tabs.size = 2
# automatically indent each line
editor.indent = true
# enable/disable auto-close of curly brace
editor.auto_close_braces = true
# size of divider between editing area and the console
editor.divider.size = 0
# the larger divider on windows is ugly with the little arrows
# this makes it large enough to see (mouse changes) and use,
# but keeps it from being annoyingly obtrusive
editor.divider.size.windows = 2
# automatically save sketch when verifying or uploading
editor.save_on_verify = true
# any additional java options when running externally
# (for applets that are run external to the environment...
# those with a code folder, or using any libraries)
# if you hose this and can't run things, it's your own durn fault
run.options =
# settings for the -XmsNNNm and -XmxNNNm command line option
run.options.memory = false
run.options.memory.initial = 64
run.options.memory.maximum = 256
# example of increasing the memory size for applets run externally
#run.options = -Xms128m -Xmx1024m
# index of the default display to use for present mode
# (this setting not yet completely implemented)
run.display = 1
# set internally
#run.window.bgcolor=
# set to false to open a new untitled window when closing the last window
# (otherwise, the environment will quit)
# default to the relative norm for the different platforms,
# but the setting can be changed in the prefs dialog anyway
#sketchbook.closing_last_window_quits = true
#sketchbook.closing_last_window_quits.macosx = false
#history.recording = true
# for advanced users, enable option to export a library
#export.library = false
# which platforms to export by default
export.application.platform.windows = true
export.application.platform.macosx = true
export.application.platform.linux = true
# whether or not to export as full screen (present) mode
export.application.fullscreen = false
# whether to show the stop button when exporting to application
export.application.stop = true
# false will place all exported files into a single .jar
export.applet.separate_jar_files = false
# set to false to no longer delete applet or application folders before export
export.delete_target_folder = true
# may be useful when attempting to debug the preprocessor
preproc.save_build_files=false
# allows various preprocessor features to be toggled
# in case they are causing problems
# preprocessor: pde.g
preproc.color_datatype = true
preproc.web_colors = true
preproc.enhanced_casting = true
# preprocessor: PdeEmitter.java
preproc.substitute_floats = true
#preproc.substitute_image = false
#preproc.substitute_font = false
# auto-convert non-ascii chars to unicode escape sequences
preproc.substitute_unicode = true
# PdePreproc.java
# writes out the parse tree as parseTree.xml, which can be usefully
# viewed in (at least) Mozilla or IE. useful when debugging the preprocessor.
preproc.output_parse_tree = false
# Changed after 1.0.9 to a new name, and also includes the specific entries
preproc.imports.list = java.applet.*,java.awt.Dimension,java.awt.Frame,java.awt.event.MouseEvent,java.awt.event.KeyEvent,java.awt.event.FocusEvent,java.awt.Image,java.io.*,java.net.*,java.text.*,java.util.*,java.util.zip.*,java.util.regex.*
# set the browser to be used on linux
browser.linux = mozilla
# set to the program to be used for launching apps on linux
#launcher.linux = xdg-open
# FULL SCREEN (PRESENT MODE)
run.present.bgcolor = #666666
run.present.stop.color = #cccccc
# starting in release 0159, don't use full screen exclusive anymore
run.present.exclusive = false
# use this by default to hide the menu bar and dock on osx
run.present.exclusive.macosx = true
# ARDUINO PREFERENCES
target_package = arduino
target_platform = avr
board = uno
software=ARDUINO
# Warn when data segment uses greater than this percentage
build.warn_data_percentage = 75
programmer = arduino:avrispmkii
upload.using = bootloader
upload.verify = true
#default port is empty to prevent running AVRDUDE before Port selected (issue #7943)
serial.port=
serial.databits=8
serial.stopbits=1
serial.parity=N
serial.debug_rate=9600
serial.line_ending=1
# I18 Preferences
# default chosen language (none for none)
editor.languages.current =
# Disable saving of preferences.txt file (settings will not survive Arduino IDE reboot)
preferences.readonly=false
# Debugging/Development Preferences
# Disable signature check on packages_index.json, use only for
# development/debugging purposes. Do not enable in production.
#allow_insecure_packages=true
Please take a note of the very first lines in that file:# !!!!!!!! UNLIKE PREVIOUS VERSIONS OF PROCESSING !!!!!!!!!!
So you shouldn't manually (have to) edit this file; I expect trying to get your problem fixed using this route won't work. ![Idea :idea:](./images/smilies/icon_idea.gif)
This file is located in /Program files (x86)/Arduino .
But the file i need to replace is the per-user version preferences.txt file located in /Users/Username/Local/AppData/Arduino15 .Which i think i've missed up with it.
Pablo2048 wrote:Try to use portable installation of Arduino IDE. Preferences.txt file is then inside portable directory...
The preferences inside portable isn't what i really look for .
Idk, Where can i find files which prepare Serial and Network ports to show it in Arduino IDE ?
The upload via network port is working well using command prompt.
