Chat freely about anything...
By eriksl
#82349 BTW the current release has a nasty bug where the IP handling can become unresponsive when traffic is sent in quick succession. This is due to the receiver buffer being locked before processing starts and the processing procedure (which is supposed to unlock the buffer when it's finished) is called via a task queue. The task queue for this was a bit on the small side so it could happen the queue would be full and the processing procedure would then never be called and the buffer remained locked. This has been solved.
By eriksl
#82351
Code: Select all0001640   =   0  nl   i   o   .   6   .   0   .   f   l   a   g   s   =
0001660   1   2   8  nl   i   o   .   6   .   1   .   f   l   a   g   s
0001700   =   1   2   8  nl   i   o   .   0   .   0   .   m   o   d   e
0001720   =   3  nl   i   o   .   0   .   0   .   l   l   m   o   d   e
0001740   =   3  nl
0001743
There is only one "nl", there should be two, adjacent, making an empty line.
By holopaul
#82352
0001740   =   3  nl
0001743
i see. thanks. what text editor are you using ?
