setup-osx-compiler-esp8266 [2015/03/10 20:31] xjdkhq [esp-open-sdk] corrected typo |
setup-osx-compiler-esp8266 [2015/08/19 16:58] jseb [Dependencies] |
Line 18: | Line 18: | ||
brew install grep | brew install grep | ||
brew install autoconf | brew install autoconf | ||
- | brew install binutils (for gobjcopy) | + | brew install binutils |
- | brew install gawk (required overwriting the non-gnu awk in my case) | + | brew install gawk |
- | brew install autoconf | + | brew install wget |
+ | brew install automake | ||
+ | brew install libtool | ||
+ | binutils is needed for gobjcopy | ||
+ | gawk is required for overwriting the non-gnu awk in my case | ||
If you get the error "configure: error: could not find GNU awk", run | If you get the error "configure: error: could not find GNU awk", run | ||
Line 30: | Line 36: | ||
==== Dependencies ==== | ==== Dependencies ==== | ||
- | sudo port install gsed gawk binutils gperf grep gettext py-serial | + | sudo port install gsed gawk binutils gperf grep gettext py-serial wget |
==== Get the compiler ==== | ==== Get the compiler ==== |
